Hi All,
I'm looking to upgrade my existing case & CPU cooler in order to maximise the overclocking potential of my i7 4790k
Background:
I have an older pc setup (4790k) in a
Fractal Design Core 2300 case. I'm using an Arctic Liquid Freezer 240 (the 1st, not 2nd) upfront, but the tubes are at the top, and the front panel is enclosed, which are both limiting potential (and I can now hear pump/exchange whine).
Mobo is
Asus z97 Pro Gamer
Ram is
Kingston Beast 1866
GPU is
Sapphire VEGA 56 Pulse
Desk space limits the new case to H475mmxD480mmxW230mm.
Desk space is open, other than the top of course (
Ikea Fredde).
Cases
I've been looking at the following mid cases, which should fit in the space:
Phanteks p400a
Fractal Design Meshify C
Be Quiet dx500
And with potential issues:
Corsair 4000d Airflow (part-picker says the front panel won't work with mobo).
Lian Li 215 (potentially slightly too tall).
Cooling
I'm looking at:
Arctic Liquid Freezer II (240/280 depending on compatibility).
Big Air:
Noctua NH-D15 Chromax
Dark Rock Pro 4
(Although some cases state 160mm cooler limit,
I've seen reddit posts of noctua d15 (165mm) in phanteks p400a)
Other smaller 'big air' coolers.
Question
Which of the following would provide the best/optimal solution:
1. Arctic 240mm in 'best' airflow case, such as Phanteks p400a (seems easiest/most compatible, but is it 'best'?).
2. Arctic 280mm in Lian Li 215 (case squeezed into the desk, ~20mm space for exhaust).
-280mm would limit me just to Lian Li 215 in order to install at the top of the case, to keep tubes on the bottom of the radiator.
3. Big Air squeezed into any of the mid cases (
I've seen it fit, but would it limit airflow for GPU?)
-Also, would a Big Air cooler fit on an older board like mine? Looks like it would, but I'm not certain...
Ideally, I'd go with Big Air so that the cooler will last longer, and so be useful in a future upgrade, but it seems as though it'd have more compatibility issues, ironically.
TL;DR
looking for the 'best' cooling upgrade option for an aging setup, and it would be nice to also have it compatible with a future upgrade to Ryzen, for example.
Ta much!
M
