Upgrade Suggestions?
Probably retain the case I have if there is not any options.
Looking at the 7800x3d over the 7700x
I know the 7800x3d is a more gaming focused but will be fine for the purposes of video editing as well?
Was looking at the Dark Rock Pro 4?
And GPU Wise I'm debating on a
Gigabyte GeForce RTX 4070 WINDFORCE OC 12G Graphics Card
But I'm only going to be doing 1080p Gaming looking around a 4060TI or 6700xt or the 6750xt?
The CPU Cooler I'm looking at is the
Thermalright Peerless Assassin 120 SE CPU Air Cooler​
The GPU's I'm looking at are:
Gigabyte GeForce RTX 4060 Ti 16GB GAMING OC Graphics Card​
Or
Gigabyte GeForce RTX 4070 12GB GAMING OC Graphics Card​
Or the XFX 7800XT
Any Pointers?
Or
Or the XFX 7800XT
Any Pointers?
Thermalright cooler great.
The 7800xt is slightly faster than the 4070 in games but if you prefer ray tracing Nvidia is better.
If you get a Nvidia GPU then look at the Zotac versions as they come with a 5 year warranty if registered within 30 days otherwise it's 3 years.
It’s a pretty easy choice unless the RTX4070 is a decent amount less money. The 4070 is slower and has less VRAM than the AMD card.
I think it's better to say that it's situationally slower, although the 7800XT seems to come out ahead more often than not when looking at raw performance.
When speaking of "features" I'll also take DLSS over FSR any day of the week, and unfortunately upscaling is an unavoidable reality.
Regardless, either is a good buy and I absolutely would not spend, say, £50 more on a 4070 over a 7800XT.
I wouldn't be buying any gpu until nvidia release their super cards next month..the 4070ti super will get 16gb vram and memory bus increased from 192 to 256 bit. that with more cuda cores, and i was reading it should be closer to the original 4080 in performance, the larger memory bus shouldn't gimp it when at 4k now and if comes in at same price will be a lot better price to performance than exisdting card..the 4070 super also s/b a decent bump with a 21% icrease in cuda cores...will be interesting to see how pricing goes, and how amd will respond
