- 18 Mar 2008
Hi, I've just done a few upgrades on someone else's machine. I've put in a new psu, ram, and gpu.
But the problem is that the mobo takes a 20pin plug, rather than 24. So I've put the 20 in, but there's a separate 4pin plug on the mobo. The psu's 4pin cable is attached to the 20pin, and isn't long enough to stretch to the slot.
And so, the pc turns on, but nothing comes up on the screen. What can I do?
This pic shows the 4 pin and the 4pin plug.
Thanks
Thanks
