Using Multiplugs
I have a multiplug with "slave" and "master sockets". The slave sockets turn off if the appliance plugged into the master stops drawing power. I can turn off my PC remotely (I have a smart plug plugged into it) and it turns off my monitors and my desk lamp etc. It's on a timetable and switches on and off automatically as I leave or come back home.
This kind of set up gives lots of options.
  • Like
Reactions: NE5
smart plugs are an option.
i use one of these to manage a light as part of an alarm clock along with a socket timer.
Benifit of a remote to turn everything off, or individual plugs, then have the light turn on at set times if the main socket has power.
but honestly i leave everything on usually and dont really turn anything off for any periods of time.
Step 1, turn router off using smart plug.
Step 2, errrrrrm.
Plugged into the wall without anything else sharing the wall socket
So what's the question? Can you leave them on? A few appliances (which sound like they will be switched off) isn't going to be a problem over the weekend. I mean, it's not a problem if you are looking at it, is it?
(genZ don't know how to wire a plug so a multiplug would be alien to them - delulu)
Desktop unless in standby is going to be burning electricity several units a day - hasn't everyone checked out the power consumption of their gadgets when they had their first smart meter ?
so I'd unplug a desktop for starters, unless I'd burned money on a solar setup.
Eventually I might be brave enough to charge my legit ebike overnight on the cheap night rate, using a timer plug!:eek:
Ok, I will bite...
A solar setup is the very definition of stopping you burning money
if you have increased domestic consumption due to unecessary plugins,
that reduces break-even time for expensive solar/battery installs, which for for me on 6odd units a day would be a long 9 years(may be in new property then)
ie solar expense wouldn't be justified if you turned stuff off.
when I got smart meter and energy monitor plug I realised the naim amp I'd previously left on 24/7 was a unit a day, and decided that saving from turning it off when not in use would offset the
sonic&reliability concerns I had had.
