Good afternoon all,
So I bought a pretty decent gaming rig back in October 2019.
650W Seasonic Focus Plus Gold Power Supply
Ryzen 3600 4.2ghz
Sapphire Vega 64 Nitro +
Kingston 480GB SSD
Seagate 1TB
Cryorig H7 Single Tower Heatsink with 120mm Fa
B450 Aorus Elite
Corsair 16GB 3000mhz
It's been pretty smooth sailing apart from the odd BSOD (Unexpected Store Errors, Critical Process died - these happen a few times a week), but when gaming, if I put the fps up then invariably my GPU's temp will ramp up and get to the point where the game will just shut itself down - I presume to avoid any damage.
I've believe I've narrowed it down to FPS because I can have everything else on Ultra settings no problem (this is Witcher 3, Divinity Original Sin 2, Age of Empires II, Dragon Age 2) but these games are only playable if I lower the FPS. For example, Witcher, I can play on 30fps (temps hit about 55c) but as soon as I put it on 60fps then it's 70c+ and goodnight sweet Geralt.
Seems a bit strange given these are quite old games and my machine is pretty nifty. Back when I first got the machine I installed the newest Call of Duty and also Plague Tale Innocence, which are both very graphic intense games. I didn't play them for extended periods of time though so I can't remember if they did cause the GPU to overheat or not, but I could definitely play them on Ultra settings too.
I opened up the case to have a look to see if it's dust build up but there's hardly anything in there and I did blow out what I could.
Any ideas what could be up? I'm hoping it's something simple I'm missing, because I didn't spend all this money on a rig only to play games at 30 fps (it's quite a difference when going from 60 to 30, especially on something like Witcher).
Thanks for your time.
Ryzen 3600 4.2ghz
Kingston 480GB SSD
Seagate 1TB
B450 Aorus Elite
