Victorian renovation build log
25 Sep 2016
Thought I would log my current house project.
Its a 5 bed semi built in 1869
Not decorated since the 70s and stood unoccupied for over a year before I bought it (for a bargain)
I have done little bits to make it habitable - ie. temporary roof repairs, and double glazed front windows
Latest big project is a small extension and kitchen/breakfast room revamp, that I'm still soldiering through now!
Old lay out - room with the lady is (:D) in kitchen, looking at the back of the house
hope you can appreciate that most of the light and garden access/view is blocked by the outrigger, which was an unheated overly large utility room
plan was to make an L-shape and add lots of glass
more to follow....
Ha, we're literally looking at getting an architect in to get plans drawn up for almost the same thing in the new year :)
Keep us posted!... so I can steal your ideas :D
Watch out for that roof pitch, only certain tiles will go shallower than 22.5 degrees* unless you build it as an onduline roof.
* some marley interlocking tiles will go as low as 12 iirc
Interesting project. I'm looking at doing something similar later this year but extending the outrigger by a couple of metres to have a separate kitchen and dining room.
What plans do you have for the flooring, will the existing kitchen and utility room extension have the same sub floor?
Work is nearly finished, plenty of hiccups on the way but nothing major.
Didn't want to lose much garden and house is big enough already, so didn't want to extend out. It was more about creating usable space, light, and garden views
Work began in September lol
Il try and post chronologically
Foundations being dug, you can see it's not a very big space increase
New insulated slab for new section and utility, same level as the old concrete slab of the kitchen.
Floor will be limestone slabs
Oh and I think the roof pitch is 25degrees
the foundations are only 6 bricks deep on to soil so the back walls needed underpinning
fortunately the structural engineer had accounted for this
Here is the underpinning continuing along the internal wall that will take the weight of the largest piece of steel
you can see the set concrete in the right of the hole, and a spade for reference of how deep the hole is!
Main problem with the house is no matter how much the heating is on it never gets particularly warm in winter.
Because of this I am insulating internal walls with minimum 50mm celotex, and all new walls are insulated cavity walls
love that diagonal steel, very cool :)
That's a very small overlap on the main beam, guess its not carrying a huge amount of weight but i'm surprised you don't need more.
Thanks guys!
The overlap on the rear higher horizontal steel is 150mm on to original wall
The overlap on the front lower horizontal still is only 100mm because it's onto a new double skin wall - looks scarily little but his is current building regs!
The vertical 'solider' bricks across the top are to tie it in architecturally with the original brickwork above the windows that you can see in the first site photo
Are your original walls cavity? If so, you can still get free cavity insulation as well as your loft done. We did it all for free and it definitely improved the heating situation.
Cavity wall insulation! Run as fast as you can 'away' from it! Don't put it in. The cavity is there for a good reason. Different if a new build as its done differently.
Have you had a bad experience or something? Interested to know.
I assume it's a case of YMMV. We've had nothing but good results these past 2 years since instalation.
