Victorian renovation build log
Chimney breast opened up for range cooker
There was a lot of brick in there! Must have gone through about 5 different cooker/fire/chimney configurations in its 160yr life time before it was finally bricked up!
boarded out
new 70mm lower ceiling to hide pipe work. Had them use acoustic board as the room above is a bedroom
skimmed and the floor being laid.
The floor is tumbled umbrian limestone laid in a vertical/horizontral herringbone pattern to stop the room looking too long and narrow
That is a really great job, the final results are going to be stunning. I really like the flooring!
How did you go about starting this task. Do you contact a builder or an architect first?
We are going to look into similar this year for our house and would like to know best plan of action.
The floor looks much better in person, much more natural tones, looks like it's been there forever.
I'm obsessed with natural materials. Limestone floor, solid wood kitchen and granite worktops!
Re: Hedge
I tired to do them simultaneously but found without hard copies of plans builders were vague and didn't really take me seriously.
As soon as the plans were done I was able to get itemised quotes and start dates quickly!
I'd recommend getting plans first, only downside is that some of the design features may turn out to be expensive and have to be edited once quotes arrive!
kitchen in its raw state.
Was going to get one from DIY kitchens but then found an awesome joiner who worked out the same price (as long as I do a lot of painting!)
painted the walls
lots of undercoating to do on the units
fitted new lights (not to everyone's taste I'm sure but the rest of the kitchen will be quite plain)
can see the new cooker in the background too
Brace man taking on the painting of the units not sure I'd have the patience to take on the 4-5 coats they are going to need!
painted the walls
A good spray gun will be your best friend here so you dont end up with lots of brush strokes.
