Hope that helps.I don't get capped after 12.Gav said:I am on 20meg and hardly make it above 5meg. The 20meg connection isn't worth the money unless your downloading millions of files and can handle the restrictions between 4pm and 4am. Not between 4 and 12 like VM would like you to believe...
Thats my latest speedtest...
Trifid said:For the ADSL part, 5KM is a bit much for the speed of ADSL2+ being over 8Mb. http://www.internode.on.net/adsl2/graph/index.htm suggest 3KM.
Trifid said:I was showing it for the 8meg and ADSL2, and not the 1.5Mb ADSL, which as far as I know is using the same technology, so should be the same distances.
thanks virgin media and http://abcde.co.uk/virginmedia/broadband-faq.html#q10 for that oneTrifid said:So can my point of not getting 8meg at 5KM wire distance still hold?![]()
xgeek said:Virgin have released their 20Mbps compatible modem list today:-
http://allyours.virginmedia.com/html/existingcustomers/faster/current_service.html
If you are on the XL package and your modem is not supported they will send you out a free one. Just ordered a new modem as my SB4100 in not compatible.
