I have tried both the 64 bit RC1 and the 32 bit, and cannot get either to complete. I previously installed Beta 1 with no problem, just lots of driver issues, but even after a format, both RC1 releases fails.
Symptoms are it starts to load windows fine, going through expanding and installing files, it reboots, and says wait a while, followed by a series of dots going slowly across the screen. It then reboots, and shows RC1 in the bottom corner, and the build number, but after a few minutes, the screen goes off, but the hard disk still flashes for about ten minutes, and then stops. I have tried leaving it alone for an hour, but it just sits there. I reboot, and tried going into safe mode, but it shows the message safe mode in each corner, but says I need to complete the install and to reboot, which I do, but it sits there with a blank screen.
I have an Asrock dual sata with AMD64 4400 dual core, and 2 gigs of Ram. Running the new Vista compatability check program tells me it will work but I will need new drivers for my sound card, (a rather old but gold Hercules
Theatre 7), but otherwise OK.
I am running on the latest Asrock 2.2 bios, and have tried with no overclock.
Anyone any ideas please, I am losing heart.
