Our nearest supermarket is a waitrose. I don't find that it's necessarily expensive, they just don't bother stocking cheap stuff. You only get a choice between top branded products or their own stuff which is good and priced accordingly.
so no "waitrose value" beans then?kaiowas said:Our nearest supermarket is a waitrose. I don't find that it's necessarily expensive, they just don't bother stocking cheap stuff. You only get a choice between top branded products or their own stuff which is good and priced accordingly.
toucam said:Waitrose is sort of like M&S but not as good and as expensive but still rather expensive.
?Zefan said:You should've seen the waitrose nearest Reading Festival.
Queued for about 20 minutes just to get some bread and some spicey meat![]()
axe said:yeh but do they have self serve tills like my tesco?
currently partaking in a Chamai Blue ... hmmmmm alcoholicThat's because it's owned by John Lewis.DAVEM said:reminds me of mix between sainsburys and john lewis.
Scuzi said:I usually shop at the Waitrose here in Windsor for odds and ends. It's a bit small so I use Tesco for the majority of my shopping but for main ingredients for meals like meats and whatnot, Waitrose are hard to beat as far as supermarkets go.
It's more expensive but you get what you pay for.
Same - Take it off the shelf, scan it, pack it. Job done. No having to handle all the stuff you buy twice like you do at Tesco. Also, you get running totals and alerts whenever you scan something that's on offer.laissez-faire said:Yes. In fact in our local they go one better, you scan it as you put it IN to your trolley so even less fuss!
