Lucid, et all.
So yesterday I got a windfall. I come home to a letter from the Inland revenue saying I'm getting a £700 rebate. So the purchase of a projector just got sped up quite considerably!
I've been thinking about it a lot, I'm certain I want it. I can't see me not liking it (when being realistic about it
Also last night, using what little is in my house at the moment (all my belongings are at my ex gf's at the moment) I marked out the rough size of a 90" projector screen.
My...word...it's hard to fathom!
- To give anyone else the idea of size, that chimney breast it's against is 57" wide....
Now I'm currently deciding on how to mount the Projector, I will think about the screen afterwards as there are more options/variations for that.
I'm really liking the look of the Optoma HD30, nobody has anything bad to say about it, and I can find one online for £629 refurbed directly from Optoma.
I'm thinking of going for a ceiling mount. I want to keep the wall it'll be closest to as clean as possible as I have some artwork planned for it. Plus with it ceiling mounted I should be able to get the image at a good height.
My ceilings are 8ft something (it's in this thread, I can't remember exactly) so its pretty close to the diagram, making it ideal.
However, it will mean (I assume it will anyway) ditching my lampshade and swapping out for ceiling spots...which I don't mind, it just means more work...ah well, Rome wasn't built in a day
Going from this, I'm back at screens. as you can see from the above image if I was to wall mount the screen I would have to have long brackets coming out from the alcoves and the screen I think would be an eyesore, and generally bug my OCD. So I'm back at looking for a ceiling mounted one.
Are screens available that bolt to the ceiling rather than having to sit in it? I wouldn't mind fitting one into the ceiling, but again it's more work. If one is available that will just bolt to the ceiling, I would be happy with that.
What say everyone?
EDIT: Oh and as you can see the wall bracket is now up, cheers for the help on that!
