- 29 Feb 2012
- London
Pgreenwo in the mobo manual it suggests slots 1-3 for best performance ???
I got the hard drive cages out. Very annoying !!! 240 comes tomorrow so should be up and running
With pictures by the weekend. Only working until 4 this week so gives me so evening time to work on it.
I've put the compression fittings on. Do you do the ring up as well?
The bit you tighter up if your doing it in your hand they come apart and you
Are left with 2 bits
Pgreenwo did you plug the fan cable in from the res/pump when filling the loop???
I'm at that stage everything is finally going good![]()
hmmm plugged psu in and the and the molex in nothing happens when i switch it on???
am i doing something wrong?
