water cooling help
16 Apr 2012
Hemel Hempstead
hello i need help with finding the right water cooling kit/set-up. i currently have a i5 -4670k and 2x r9 290 sapphire tri-x cards that i want to water cool i have a nzxt swtich 810 case so i can fit a 360 rad. any help as this is my first time water cooling my pc (other than my all in one h100 cooler)
From a rough spec I would say you're looking at £520 ex pnp. A little cheaper it will depend on the GFX blocks that will fit your cards.
CPU block £52
GFX block = £165 for 2
Pump & Reservoir = £105
Radiator (3x components) = 360rad £54 240rad £30
Tubing £17
Compression Fittings £50 (Monsoon 2x 6 packs as you need 10 of them)
Fluid = £10
Fans x5 (£6.66) = £34
D5 will easily power that, I use it with a GPU block, CPU Block, 2 rads and it is fine even though it's on the lowest speed.
My biggest concern is that you won't have enough rad space. Some googling suggests you can fit a 360mm and a 240mm in that case which I would strongly suggest for 2 hot GPUs and a CPU.
is strong enough to cool my i5 and 2x r9 290's?? and for the xtx 360 rad?
lol yeh,
I have mine on setting 3 cooling
4790K
R9 290X 8GB
R9 290X 8GB
360 RAD
280 RAD
Pump res
Just played 2 hours of gta v CPU temp 55C, GPU's 48C GPU VRMs 55C.
and thats with 3 fans up 1/4 of the way and 2 on the verry bottom. totaly inaudible
iv'e picked the parts now, just need help with what size tubing and compression fittings i need. thanks for all your help guys
ps. once i get all the parts and sleeving il post my build :)
pump/res - XSPC D5 Vario Pump & EK-D5 X-RES 100
cpu block - EK Water Blocks EK-Supremacy EVO - Acetal+Nickel
gpu block - EK Water Blocks EK-FC R9-290(X) - Acetal+Nickel Rev.2.0
rad - alphacool xt 45 rad/ 240mm and 360mm
Buy 2 or 3m worth,you always want to have more than you think you will need.
Also avoid xspc tubing if possible,get the primochill LRT
