Yes, all definitely unplugged. My husband knows how to fix most things but inside a computer is a different story but he'll try.Can you post a picture of the insides of your computer? If you aren't sure, probably worth getting someone that knows computers to have a look. The youtube video above is showing like the main connector which comes off of your power supply unit. This plugs into a large circuit board bigger than anything else. That's the main PSU connector. Make sure you unplug from the mains before you go prodding around inside a potentially water damaged PC.
It's possible you have just water damaged the area you posted a picture of which sends a signal to the main board (motherboard) which in turn, turns the actual PC on. There is a bypass you can do manually using a screwdriver to get it to turn on, but that's difficult to talk you through without showing you pics in detail.
Cross your fingers?I've removed the 24pin connecter from the motherboard and I have shorted out pin 3 and pin 4 as per the YouTube video posted above and I'm about to turn it on to see if the PSU is working.
Do I need to do anything else first?
I've just powered it up with the shortout wire on pin 3 and 4 and the PSU fan fires up as well as the usb fans. Everything else is disconnected from the board.You can still do that if you like. All you need to do there is turn the PC on at the mains and press the rocker switch on the back of it to see if the fan spins up. It probably will.
Fingers were well and truly crossedCross your fingers?
Some peoplee recommend removing the other power connectors from the PSU (HDDs, CPU, etc). I never have but up to you.
(If I run out of 'allowed' comments I'll come back to my last comment and keep editing it)
Before doing what you said above, I don't know whether I should plug the hard drives and all the other connectors that come from the PSU back onto the board and do the short test again? Could it still be an internal fault in the PSU?Yeah so it so far is sounding like it may well just be that small little circuit board which does the power/reset/activity led/usb ports which might be fried. If you do as I said above shorting out the pins, it may well fully power up. It's basically powering it up by not using the power button which could be dead.
Can I just ask.The paper clip test is just literally to test the power supply unit works. You've proved it does.
Next thing is plug everything back how it was and short those pins I said and I reckon it will boot up. If it doesn't, post back, there are other things you can try.
Can I just ask.
If it's possibly the switch panel/led/usb panel at the front of the tower, do I need to disconnect this before powering up just incase the short is still there?
Thank you. If it does kick into life, what do I do then? Is it ok to take the screwdriver straight off?Yeah where the wires all go into that place above in the image I posted, you can actually pull ALL of those wires out of the main board. So if you want to be safe you can pull out the ones doing the activity LED, reset switch, usb ports etc. Reason I said not to, is it can be a fiddle to get them perfect on the right pins so was trying to keep it simple to start with.
If the short it still there, it is unlikely to do damage, but more likely to simply affect operation of the LED, USB ports and/or reset/power switch. Up to you.
