Watercooling advice
I'll stick with a T i guess :p
When you add the T fitting, on the bottom you'll put a bit of tube but what on that to block it?:p
As it's barbed you can't put the G1/4 stopped on it so what would I also need? :p
You could put a QDC at the end, you could clamp it, you could even have it lead to another t fitting back into the loop :D:p
Ok so;
Res -> Pump -> Waterblock -> Rad -> Res
Between Pump -> Waterblock two T-Line's
Between the T-Lines a bit of tubing bent to fit on both, when I want to drain, just remove 1 of the bits of tubing from the lower T-Line
I thought there'd be something you could buy, so you could like 'plug' the end of the tubing.
edit;
http://www.overclockers.co.uk/showproduct.php?prodid=WC-233-OK
Would that work? :)
Edit 2;
Instead of that ^, a 1/2" ID Sealing plug from competitor
Also, would a nickel plated brass T-Fitting be fine?
Ok so;
keep the T line before the res :)
edit;
Would that work? :)
Edit 2;
yep :)
Yes, that's fine
T line before res?
as in between Red -> Res?
As that'd be top of case, wouldn't it be easier between either
Res -> Pump or between Pump -> Waterblock
As Res = 5.25" Drive, Rad = Top of case, CPU = mid, Pump = bottom
Figured it'd be easier and safer to have t-line at bottom
Reason I say T line before res is so that you can easily drain it then as you want te pump to always have fluid, but you don't want any returning to the rad :)
Surely if you put t-line before res then the liquid in the res won't be drained?
I always thought T-Line for draining would be best at the bottom of the build.
That way, once drained and you fill it up again, the liquid is instantly going to pour down to the pump before it's even turned on surely?
Also, if I were to add another single rad how much you reckon it would change the temps, or not even worth it?
the res is always supplying the pump with water, so by making sure nothing returns to the res , the pump won't be pumping anything. Anything the pump does pump, will go straight out . If you had the T line after the res, then it would o through the res and into the pump again and be pumped around another time.
Thet depends if you want gravity or the pump to do the draining. easier to have the pump do it :)
3-4 deg? Just a guess.
a 360 is enough
Oh, I leave gravity to do it :p
I'll leave it with 1 360 until I add a gpu block then :)
You seen any elysium project logs? can't seem to find any watercooled elysiums, well seen one on OCN but other than that :p
nope :(
want to do one though :D
The elysium seems to be a hafx with more rad space :p
Plenty of haf x logs availables
Yeah I seen tons of HAF X logs as that was my original case of choice (can't remember if it was you or someone else who suggested elysium) but who ever did, I liked the look of it and it looked easier to work within but couldn't find any logs.
I like the look of black + red builds though, hence my reason for getting the red bitfenix alchemy pre-braided cables, red LED fans, and i'll probably through in some Phobya LED strips.
Now I can't wait to get this, shame I won't have time until after exams :(
