Hi. I just set up a new pump in my case, but it leaks around the outlet adapter. I basically need some sealant - Anyone know which type to get? Silicon PVT stuff?
Also, do I have to drain it completely in order to seal it properly?
Also, the picture on my monitor has started kind of vibrating - I guess this is from the pump (eheim 1048). Should I just put my case on the floor?
Plz help ASAP or my case will fill up with water and I will blame you all
