Why would I puncture? It would have to be a pretty big shred to stop the sealant from working.Lol. And if you puncture on rides like that, you just quit, yeah?
Probably wears short sleeve tops, ankle socks and can't ride in a bunch worth a **** either.
Bunches are for the men who prefer the company of other men. Solo is where it's at.Probably wears short sleeve tops, ankle socks and can't ride in a bunch worth a **** either.
My approach is to take an extra canister or 2 of CO2, and have a tiny pump for absolute emergency use only.I've had a couple of punctures recently and my bigger concern now is generally getting air pressure back in once fixed/replaced. I have one of these and tend to find I don't get enough air in. There are two possible reasons. 1) I'm just not pumping hard enough, long enough 2) It's not a good pump.
I think it's very possibly option 1. I pump and pump and to the feel of my hand squeeze, it seems good. I then hop on and can see it's not enough pressure. I should probably just hop back off and get pumping again, but so far I've generally only had a few miles to go, so just get home and use my larger pump to get up to the correct PSI.
Is there a better pump out there I can take with me? Or should I just put more effort in. I notice one review says he gets up to 110psi with this pump, so I assume I just need to put more effort in?
**EDIT** I'm actually also ordering some CO2 and a control valve...
I was in the saddle bags are way uncool club until....
The Silca range came out
I use their saddle roll with boa, there is no rocking, movement or noise, it holds everything in place and has held up to the weather OK so far. Plus it looks good and ticks right under the saddle so it isn’t like some offensive ballsack rocking around.
I have one tube, two co2, levers, nitrile gloves, a 3” piece of old tubular tyre a small bit of a spoke (for stuck valves/poking stuff) and a basic multi tool (Allen and screwdriver).
I've got one of these - the pump is fairly poor, but effective enough to put enough air in to seat the tyre, then use the CO2 to fully inflate
https://www.wiggle.co.uk/lifeline-hybrid-co2-mini-pump-race/
Yeah, that's my idea. Get the new tube on, use the mini pump to check all seems okay (twice I've had new tubes with punctures before I even start!) and when air seems to hold, I'll use CO2. How do I know when CO2 has got the tyre up to pressure? It stops? Or I just judge myself?
I think it's a bit wasteful using C02 at home.
