Productivity. 16:9 became the standard for TV's as it was the best compromise between 2.35:1 cinema and 4:3 TV. Not the best for working. Even with this, I normally have the monitor on the right turned vertically so it's running at 1200x1920.I expected an answer like that, just not sure why you prefer it. I assume you don't watch any streaming/blurays at that ratio? I made the jump to 1440p ultra wide and its great (use the oled for fps/tv watching).
I agree, I've played a few older games and at 4:3 it just works, it depends on the game though. Rts's are great with a wider screen, fps gets a bit like watching a tennis match, hence the TV for those types of games. I actually bought my ultra wide for my degree as cam get more pages of word across it and for 3d modelling its far better (icons around the edge tend to get in the way at small resolutions).Productivity. 16:9 became the standard for TV's as it was the best compromise between 2.35:1 cinema and 4:3 TV. Not the best for working. Even with this, I normally have the monitor on the right turned vertically so it's running at 1200x1920.
My office has a 65" plasma on the wall, so watching anything is done on that. If I do watch the occasional thing on the PC, guess what, it shows in 1920x1080 without any stretching and small 60 pixel bars black top and bottom if I go fulls screen. Gaming is fine, it either supports the resolution and runs fine, or runs in 1080p, and doesn't use the extra pixels as I have scaling turned off, as scaling is the devil.
Or, even better, with very old games I can run them in 1600x1200. Although, I have couple of 20" Dell 4:3 monitors that are better for that.
Seriously though, ~24" 2560x1600 @ ~120hz would do me very nicely. Hell, I'd have 3 of them on this desk this very moment.
Or.... a nice 24" montor with a 16:10 resolution of 2304x1440 @85hz Oh wait... We had that 22 years ago. I still have my 2 Sony FW900's. Not in use at the moment as they're enormous and space is a limitation right now. But next year with the re-work of my office, I will have a proper area for them.![]()
Interesting graph, when it's put like that it's obvious it's very much diminishing returns past a certain point.My thoughts are this
Doesn't letting your PC run at crazy high fps simply ramp up the heat and noise of the fans?
I just got a new mid range gaming rig with i7 1270 and Geforce RTX 4070 etc and noticed when I first played a game that the fan noise were a bit noticeable. since then I set it at 60fps in Nvidia settings and it runs games on ultra silently and cool and everything looks fine to me.
I think it depends on the userTBH, I can't even hear my 4070 at 100+ fps and the hottest I've seen it is 58C so far, usually stays lower than that so I happily let it run all out and aim for anything between 80-100fps as I can't feel the benefit over 60 above that and the card is too weak anyways.
