- 8 Jan 2003
- Scotland
I do have an Ideal boiler as that's what the builders fitted when they built the house.There is a company (EPH) that does OpenTherm over two zones, though you'd go back to effectively "regular" thermostats on the wall again. If you happen to have an Ideal boiler, their own Halo Wi-Fi system also supports OpenTherm over two zones.
when all of the heating is a single system it just needs to run the pump and open TRVs where needed - the whole system runs at one temperature (as requested by OpenTherm); when the system is physically split by zone valves, then the controllers must be able to open the zone valve that has a radiator calling for heat on it.
