1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
What's best 6mm or 8 mm shower door.
Discussion in 'Home and Garden' started by Ynot, Apr 3, 2019.
  1. Amp34
    Caporegime
    As thick as you can get IMO. My shower is 10m and feels a lot sturdier than the thinner stuff. 6mm is really thin, so I’d go with the 8mm all things being equal.
  2. Ynot
    Wise Guy
    Yes, I think you right, thanks.
  3. Danm54
    Wise Guy
    Forgot to tell you about the screen!
    It definitely feels sturdier than the thinner screens, the glass doesn't flex anywhere near as much.
    The door rollers are good quality as you'd expect and the doors run nice and smooth.
    I like the chrome magnetic door seals on the 8 series, looks so much better than the push on plastic seals you nrmally get.
  4. Ynot
    Wise Guy
    Thanks for getting back, that's good to know and thanks for the feed back.
  5. Ynot
    Wise Guy
    When I was in the show room yesterday sales also showed me a 900mm quad Flair Verve enclosure (6mm glass)
    You know, it didn't look to bad either and the door open and closed very nice too, granted you would know it hadn't the weight of the 8mm glass.
    The Verve door and tray is almost £200 cheaper than the Merlyn bundle, door and tray.
    Any thoughts on the Flair Verve?
    Thanks guys for you advice so far.
  6. TripleT
    Sgarrista
    Yer go for the thickest you can. But to be honest take a look at frameless quadrants (if this isn't one already).
    Looks 10x better than framed enclisencl
  7. The Craig
    Id make sure you get a proper solid shower tray (stone resin/similar) rather than worry about enclosures as much.
    I got a 10mm glass one (pics below) and it does look high quality. I dont think the cost increase was much?
    Pics
    https://imgur.com/a/An6MQSJ
  8. Ynot
    Wise Guy
    Hi Thanks, yes I need a tray as well, You right, you cant ignore a good tray. I'm asking about one of these too.
    That's class, nice work, well done.
  9. Ynot
    Wise Guy
    Any brand your thinking off?
    Thanks on advance.
  10. Jokester
    Don
    Nothing wrong with good quality 6mm tempered glass.
  11. Ynot
    Wise Guy
    That's what I have at the moment
  12. Ynot
    Wise Guy
    Can't decide what colour panels to use inside the shower, black with speckles or white with speckles :)
  13. novaenough
    Hitman
  14. Ynot
    Wise Guy
  15. LiE
    Capodecina
  16. The Craig
    I got an "april" stone resin tray from shower trays uk.
    They were a good supplier and upgraded my 8mm glass to 10mm because it was out of stock, also sorted out damage to the panel.
    Im not sure if branding etc matrers on stone resin trays.
  17. Ynot
    Wise Guy
    Thank you all for your advice.
