What's better to wrap my sandwiches in: foil or plastic bag?
One
One
24 Aug 2011
ABQ, NM
The way I see it, there are several criteria affected by what I use.
How bad is each for the environment (plastic is in the news but how much resource is involced with digging up tin), what is better for flavor (will the plastic leak, will I get heavy metal poisoning?), what is most cost effective etc.
What do you do?
I use beeswax wraps from a well known organic shop. They're expensive but well worth it. The chemicals in the plastics will kill you. Very hard to find BPA free sandwich bags.
Tin is potentially more recyclable than plastic and while it's even less degradable it's less harmful in the environment when dumped.
Making the tin is more than "how much resource is involced with digging up tin". Mining is resource-intensive and not environmentally friendly, but it's only the start. The ore has to be smelted to extract the tin, which leaves a lot of other stuff to be disposed of. Tin ore is only a few percent tin, so most of what it mined has to be disposed of somehow after using more resources to extract the tin. Then it has to be refined, which uses more resources, and processed, which uses more resources, and shipped, which uses more resources.
More resources will be used in making and distributing tin foil than plastic wrap, but tin will have much less of an environmental impact after being dumped.
To some extent it's a moot point because tin foil simply can't be produced in adequate quantities to replace plastic wrap/bags.
Flavour shouldn't be affected by hours of contact with either material. The amount of leaching would depend on the filling of the sandwiches, but I doubt if it would be significant with either. A comparison would be difficult anyway because you don't specify which plastic. There are many plastics.
I'll throw in another option - a sealable box that you wash and re-use. That would be less harmful to the environment than single-use disposable wrapping.
Or you could go really old school and use a cloth wrap. Linen was traditionally used for wrapping food in this part of the world (with muslin gaining popularity later on) but there might be something more effective and/or environmentally friendly nowadays.
What do you do?
Tin foil will stop big pharma using their mind rays to force your sandwich to murder you. A trait that i believe this guy may value:
You know you're not supposed to eat the plastic bag as well right?
You do realise that this is 2018 and foil hasn't been made out of tin for quite a few decades now?
It's not entirely that silly. Some plastics contain some potentially harmful chemicals that can leach into some foods in some circumstances. Sometimes. In very small quantities. With no evidence of harm done by them in those quantities.
The only thing that would bother me about the issue is the possibility of inadequate regulation possibly leading to plastic that doesn't meet the regulations for food-grade plastic being used for wrapping food. Perhaps. Maybe.
Store them in your cheeks like a hamster.
Hamster cheeks. Hamster cheeks are our green future.
Edit: or beeswax wraps or a tub.
Oh dear, I really dropped the ball there, didn't I?
I knew that tin foil isn't made of tin (was it ever?), but for some reason I just read "tin" and went with it.
Having said that, everything I wrote is equally applicable to aluminium foil with the probable exception of the richness of the ore.
