I use beeswax wraps
Maybe you could train some bees to fly your sarnies to work and save on the wax paper?
More importantly, if you make a sandwich using two slices of bread and then cut it in half, do you still only have one sandwich or do you now have two?
Would beeswax yfronts keep my sausage fresh?
(Me, Foil round sarnies to hold them together, sarnies inside click lock box to protect them. )
there is a tessilation problem to resolve though ?Why do they need holding together? My wife does this with the kids lunches - can't understand needing to use foil/clingfilm/sandwich bags when they are going into a plastic lunchbox anyway.
My sandwiches/yoghurt/fruit all go in the same click lock box. Never had an issue, even when cycling to work with lunchbox in my backpack.
Well, My Cheese and pickle yesterday would have been all over the inside of my lunch box had they not been wrapped. I guess if you are using a sandwich filler it is less of an issue.
The way I see it, there are several criteria affected by what I use.
How bad is each for the environment (plastic is in the news but how much resource is involced with digging up tin), what is better for flavor (will the plastic leak, will I get heavy metal poisoning?), what is most cost effective etc.
What do you do?
