what tv weights 180 kg?
That's literally the point I expect.
It's best to ignore him, honestly. If you don't agree with his opinion then you'll go round in circles forever. As you say, plenty ACTUAL tradesmen that use them on a daily (or close enough) basis back them up as do Amazon reviews. As for the cost? £10 for a TV fixing kit containing everything you need to get your TV mounted to the wall vs £10 for 100 screws that you don't actually need and will end up getting thrown away in due course... yea. I know which I choose.Thats fine but your post although fairly typical of forum stuff is so black and white as to weaken it.. it's not "I've had some issues with them and use this now" it's "they're crap" well no, they're not. Your experience is not mine/is not everyone's etc etc
I mean do you do this for a living? If not how many times could you have used them?
Personally it's once, and I was quietly impressed. But then I don't have much experience of anything else.
https://uk.rs-online.com/web/p/products/0520447/?grossPrice=Y&cm_mmc=UK-PLA-DS3A-_-google-_-PLA_UK_EN_Fasteners_And_Fixings-_-Wall_Plugs_And_Anchors_And_Fixings_And_Kits|Plasterboard_And_Cavity_Anchors_And_Fixings-_-PRODUCT_GROUP&matchtype=&pla-440507450761&gclid=EAIaIQobChMI-dHvqI7A3gIVKrvtCh2p4QRLEAQYASABEgIc4vD_BwE&gclsrc=aw.ds
use something like that then.
it's a metal version of the grip it. not plastic
Sorry to have sparked a bit of a debate. I do appreciate you are all trying to help and that's great. I think I will go grip it, and on my head be it.
This mount seem ok? Great reviews by the look of it. How many holes would you guys do to hold this to the wall? I'm guessing 4 or 6
https://www.amazon.co.uk/dp/B001GOOGHM/ref=cm_sw_r_cp_apa_i_ruB4Bb3WDMXM1
Please excuse my ignorance but what is Dot dab and how do I know if I have it
It is the external facing wall that this will be going up on.
In times of yore, plasterboard was put up on a stud wall, made of wood. These were pretty sturdy and understood by everyone for internal walls and the inside face of any external walls too. In this way, plumbers and sparkies could do their thing, and run their cables/pipes/whatever before the wall was put up, and the wooden frame was the logical way to hold this stuff too.
Then at some point in the last 5-10 years, they decided that was too much faff, and started sticking globs of mortar onto external walls (in as random and annoying a pattern as possible), fitting an aluminium framework and just stuck dry-lined boards to the globs, screwing the edges to the ally frame and taping the joins. The person doing the globbing is normally a gorilla or apprentice trainee with no respect for any other trade or anyone buying a home who may want to do work behind the wall in the future. (I base this terrible description on what I found in my own home - your opinion may differ).
If you knock on a plasterboard wall you'll hear a different sound when its on something solid from when its hollow backed. If its studwork, the solid bits will be in nice straight lines with no gaps. If its dot n dab, they could be just anywhere. A pack of postit notes stuck to the wall where you found "solid" helps to visualise the construction of the wall.
Dot n dab could also be a cunning conspiracy to increase sales of SDS drills.
it's literally a nightmare if you have it. imagine a brick wall. then random bits of cement like glue used in dots and dabs to hold plasterboard onto said brick wall.
youtube is the best place to go for videos on how to do stuff and they will generally show you the fixings required too.
Thanks!
The practise sounds just awful but I guess it's to speed things up / cut costs?
Funnily enough I have someone coming on Monday to wall mount a 65" telly in the lounge and 2 x 40"'s in the bedrooms. Brand new build so will be Dot and dab. I'll let you know what they use to mount the tellies![]()
If I want something done and done right... I don't do it myselfI do wonder if I should just get someone in to do itI haven't great confidence
it's simple.
drill hole in wall. put in your choice of fitting. screw bracket into fittings. attach tv to bracket.
it's a 2 man job but tv's are light so you could easily lift it and get someone else to attach to the bracket.
majority of DIY is pretty simple. all you need are the right tools and a quick guide on youtube.
