Caporegime
- 21 Jun 2006
One thing we agree on
I did my 40" on my own, I need the other half to help me with the 55" but I can just about do it alone.
Just pay extra care to it being level and bear in mind anything else you may line it up against may not be.. for example I don't think the radiator mine is above in the kitchen (rarely on) is level so it does make it all look slightly wonky but you stop noticing within minutes.
Also worth using a spirit level, the last one I fitted had a wonky integrated spirit level!
the ones on amazon come with a separate spirit level int he box. i now have 3 of the things in the house i use them for picture frames, mirrors, etc now.
(just used universal Rawlplugs for the above, plenty good enough) guessing I hit a layer of insulation at some point as some fluffy crap came out of the hole after drilling
