A few C cooler, but the fans are 140MM vs the 120MM version so they move more air for less noise, slightly. Very nice cooler.Ordered an Arctic Freezer 2 420mm AIO for my 5900X, waiting for the cpu to arrive in the next few days, the AIO is a behemoth though so im expecting good things.
@LtMatt you fitted your 420 yet? If so notice much difference over your 360? Im coming from an EVGA Clc 280 on a 3800X, will be interesting to see the difference in Thermal performance
My Arctic Liquid Freezer II 420mm arrived yesterday, my first though upon seeing it was I'm going to need a bigger boat!
5800X with this
5800X with this
it's big, it'd cover whole ITX board, that's why I'm sticking to full ATX so it doesn't look ridiculousLooks huge! It may just be the photo perspective but I'm wondering if that'll fit in my Fractal Meshify C...
and you don't need to worry, I'm on Fractal Define C, which is basically Mehsify C but with solid front and it fits. Only hard part is to connect CPU 8 pin plug without removing the cooler, I prefer to install the heatsink before putting mobo in case and it took me few minutes.it's holding strong, as long as you don't push it with AVX it'll keep at around 80C in synthetic benchmarks, Cinebench R20 ~80, OCCT with small fft (SSE, no AVX) around 85, gaming around 65C, overall I'm happy.This would be my pick (nh-d15). I have an NH-D14 still in use on my 3700x.
oh, that's why I went with 15S, it has better compatibility while performance is within 1C margin to full 15, and you can still add this extra fanIt is massive. Measure up if you do buy one. I had to remove the front fan and stick with the one in the middle as it was protruding when I downscaled my case.
it's big, it'd cover whole ITX board, that's why I'm sticking to full ATX so it doesn't look ridiculousand you don't need to worry, I'm on Fractal Define C, which is basically Mehsify C but with solid front and it fits. Only hard part is to connect CPU 8 pin plug without removing the cooler, I prefer to install the heatsink before putting mobo in case and it took me few minutes.
Also if you're going to add 2nd cooler and you have higher ram then you'd probably have to stick to 120mm one. 140/1500mm are going sit so high that you're not going to close your side panel.
