can anybody recommend me a good protein powder for gaining mass/muscle as I know nothing about protein shakes/powders.
Thanks in advance!
Thanks in advance!
You won't gain muscle from protein powder. That'll be down to your exercise, recovery and diet. If you're lacking in protein in your diet then yes it'll help boost your protein intake. However it is not special it is just protein. For a cheap boost in extra nutrition it is great as well as convenience but if you can afford a decent diet without them you won't be losing out.
I normally have a protein shake just after a worked and in the morning.. just to help combat catabolism.
DP I agree carbs are important, but protein (amino acids) is also vital in repairing your muscles - carbs and protein together actually work best owing to the insulin spike acting as a catalyst for muscle repair - it's an anabolic hormone after all.
That said there is no anabolic window, or catabolism window after a workout. Sure, Cortisol is produces which is catabolic, but gluconeogensis is a slow process - waiting an hour or two for a meal won't do you any harm. That said, if you're struggling to get your nutrition right through regular diets, shakes etc... are an easy fix. However, I'd still recommend trying to sort your lifestyle/diet out first.
How long after? If its any more than 3 minutes after your final rep you've already lost all your gains from that workout anyway so you're just peeing money away by drinking a protein shake.
hi guys thanks for your replies! just want to clarify my diet and my exercising are on point. I am however struggling to gain weight for some reason. I do a lot of cardio alongside my strength building so maybe that is why its stagnating. I am hovering at exactly the 70kg point but i just want to slowly build that up to 74-75kg within the next 3 months
Thanks to OP for using my code, or to whoever it was
If you use TS6642 when registering, you'll get a free bag of protein as well if you fancies trying a different flavour. I recommend Cherry Bakewell or Lemon Shortcake
