which way do the amber case fans go in eclipse
My point was more it doesnt really matter, I know a 14 year old who I wouldnt challenge to a overclocking battle :p
THC_SsSsSnake said:
yes im a gemini and always seem to be 2 things to choose between lol
I am probably one of the most fussy people in history when it comes to buying things especially pc components, I can never make my mind up and I change from one thing to the other constantly.
In the end I just have to FORCE myself to buy it, haha.
Me and cases is the worst, I get through a new one about once every 3 months usually as there are always niggles with them, kept the v1000 and v1000+ since they came out :eek:
im glad it just not me alon then ,by the way just found this
ok ... as not to comment on the compatability issue ... all that can be said is theres KNOWN issues with current ati cards and nvidia chipsets ... and ati are working on the problem ... theres also quite a few forums on the issue ... not to mention a few pissy ppl too ... as yet iam unaware of a fix but theres a few posts here within this forum that you may want to look at
taken from the Asus independent forums
Just think of the amount of people running the ATI / Nvidia combo, then think about how many people are getting issues to put it in perspective.
Like if one PC7 case has a rattle, its nothing if it can be fixed in seconds. If 1 million have been sold.
If its 1/2 that have the issue, then it is a problem :)
Forums sometimes detract from the real world a bit to much.
You also get peoples being biased towards products :p I don't with cases but with everything else I have only used a small amount of them so do not have that much experience to draw upon.
A manufacturer will not release products unless they are working or in a good state, its just not worth the development costs otherwise.
THC_SsSsSnake said:
lol ati and Ati
by the way Yewen thanks for recomending the Eclipse 62,I *** it :)
My friend has one of them and i can indeed say it's a superb case. The looks don't work for some people, but the cooling in there is superb and the amount of space around the case inside is also really good. Gives lots of room for wire management to keep things tidy.
