Long time since, and a lot have been done
But pictures says more than words so here we go:
And this is how the water gets out of the case (I think it looks great
And a few shots of the inside. I do like how the colors comes together
The pictures and lightning is not perfect, due to my apartment is under reconstruction so my usually photo spot is filled up with boxes.
So it looks better in real life, especially the mayhems aurora looks really cool and still going strong even though there is many 90 degrees fittings.
May look after their new version 2.0 of the aurora.
I would have liked to have the whole build watercooled for you, but the EKWB waterblock + back plate for the GFX has been delayed a bit :-/
Even though the new EKWB back plates are plan simple, I will add the original CSQ circles to it to color them green like the GTX 670 from earlier.
So there is a lot of small stuff that needs to be fixed before it's done.
The PSU will get back in (used in a mining rig right now) and the last wires sleeved.
Some small spots needs to get repainted again and a few new things painted to.
Also some temperature sensors will get installed on top (green LED).
Pump may be changed to a D5 PWM pump instead if there is room for it
My original plan was to use a EKWB DDC X-res 100 under the PSU, but my measurements where 2mm of :-/
I then remembered a mod where the reservoir was on top the case, and thought that would look good with the aurora (which for me it does).
Though the reservoir could be 3 cm longer so that I could use 90 degrees fittings (more clean look), but the tube will be placed along the sides of the 180mm radiator with some clips to look more clean.
So I hope you like the looks so far, I believe it will become even better when the GFX will get watercooled and all the small stuff will get made
And perhaps a GFX more
(The other side with the big window is done, but cant be installed due to bad/low placement of the RM750 PSU power input).
