Whose case is feeling the heat?
Temperatures:
Motherboard 37 °C (99 °F)
CPU 38 °C (100 °F)
GPU 49 °C (120 °F) :eek:
GPU Ambient 39 °C (102 °F)
WDC WD1200JS-00MHB0 37 °C (99 °F)
CPU: 38°C (Venice 3200)
GPU: 53°C (idle)
HDD: 39°C
Northbridge: 51°C
It's 25°C in the room and the Shuttle's fan is cranked up to 60% from its usual 35
Both my case fans are @ 5v, my CPU is air cooled by a Akasa EVO33 with fan at lowest speed (1600 rpm). CPU is a winny 3200 overclocked to 2.2ghz.
GFX card is 6800GT overclocked to 400/1100 cooled by an arctic silencer.
It is very hot in my room at the moment as well.
Mark
don't really need the extra power of a 900mhz o/c, so I thought I'd have a go at taking my cpu back to stock speeds and undervolting it for all it's worth.
Appears to be Pi 32M stable 1.168V @ 1.8Ghz running passively at idle and folding with the fans at low rpm at about 38*c :)
Mul
All fans at lowest rpm . .
CPU Idle(ish) - 44 (10 degrees over usual temps)
Graphics card 66 - (About 10 over usual temps)
Mobo 29 - (7 degrees over the usual)
Craig321 we have very similar temps :eek:
At max load, temps only change a couple of degrees!
3500+ Venice (Akasa Evo33)
Galaxy Glacier 6800GT pre-clocked (Artic rev)
Black wavemaster with 4 akasa amber fans
my case is feeling it!!
current temps: (on msn,internet,music)
cpu: 34c
pwm ic:42c
chipset:48c
gfx: 57c
hdd: 38c
cpu is watercooled, but my room is like a sauna, got a big fan going and my windows open - aint helping! :(
Case is 40+ C and CPU is at 56C and that's when I'm browsing the web, the thing crashes a lot when I start playing games.
2800+ Barton
1.5GB of RAM
9800 Pro
and 2 DVD writers and 2 harddrives.
Nothing is overclocked. CPU cooler is a Thermaltake jobbie I bought a while ago for 20 or so quid and it has 2x80mm fans on the back and 1x80mm on the side. Case is a generic stuff I bought from a local shop, should really fit another fan at the front but it would be awfully awkward to fit. Thing could also do with some tidying up, there's wires all over the place inside. Weather isn't helping at all, virtually no wind and around 25 C here. I always wanted to buy the Antec Lanboy case and now it's quite cheap on OCUK, so might replace my case pretty soon.
CPU is at about 48c, P4 2.4ghz at 3ghz on stock cooling. GPU core is at 57c.
So they're a both a little higher than usual. But the case is awful :o
But they are still nothing to worry about. ;)
watercooling radiator is hot to the touch and warm air is comming out of both the rear of the akasa and the holes in the v1000 for the first time. :eek:
Would seem our server room at work is suffering the most in this weather. The Air con went caput sometime on friday night. When the Network Admin went in this morning, the network was down, as the air temp in the server room was a sweltering 48degrees C :eek:
AIR temp, as in the room's temperature. :eek:
Ouch, hate to think what the hardware was doing when it crashed.
Thats insane!
My mine at semi-idel:
3700 under a scythe with amber - 34
NB/SB - 46
GPU - 42
raptor 74gb - 33
spinny 200 - 27
Not too bad really but my system aint silent (start to try and make it so but it was costing too much so i though sod it)
