Whose case is feeling the heat?
Looks like I need some heftier fans to keep my rig cool. It's turned itself off three times in the last few days which means the CPU is touching 70degrees C :o
Murzo said:
Lian Li v1000+ cas temp = 28degrees
opty [email protected] temp = 28degrees
X1800XT temp = 35degrees
2GB GSKILL HZ
DFI Expert
My system is holding its on in this very hot weather, all on air as well :cool: :D
What HSF are you using to get such a low temp on your CPU?.
2GB GSKILL HZ
DFI Expert
But what is the ambiant temp of the air around the case, with air cooling that is the ultimatly determining factor.
I'm running seti@home tasks and my temps at 48 constant after several hours. Thats today though but ambient temp has cooled a couple of deg's since the weekend. I was running 50 under load.
Idle is between 37-39degs
Using a zalman 9500 cpu cooler at the moment.
dark_shadow said:
That's fantastic! Heard some great things about that case, are the wheels detachable?
Yeah the wheel are detachable and i have nothing but praise for the v1000+ its brilliant.
Not sure on my room temp im in the attic so its freezing in the winter and very hot in the summer.
Case (gigabyte aurora) no clue
Opteron 165 @ 2.8ghz 56c load :eek: think i needa get water cooling again.
Hard drive 36c
gpu (x1900xtx) 55c (idle around 93 load)
My room temps went from 21 (Average) to 29 during the warm spell which saw my idle temps go from 34 (fan at 30%) to 38-40 (fan at 75%)
