Hi all,
Got a strange issue. Had NZXT CAM software installed (for the LED controller) which has highlighted a serious issue with my temperatures. It kept popping up about the temps going over 80c and prolonged use like this could cause issues. So I looked into it and sure enough, it is running very hot quite often.
A couple of years ago when I installed the H100i I remember not being overly impressed by the temps, but I don't remember it being anywhere near this bad.
I don't game at all really - just a general use PC. This is not an overclocked system (it was, but that seems to have been lost at some stage).
So running at the standard turbo mode 3.7GHz, literally just web browsing and these are the temps. I have installed Corsair Link software and put all the H100i fans and the front intake fans into performance mode (full RPM I believe) and even after 10 minutes these are the temps.
It is extremely high and I just don't understand.
Any thoughts? Might re-apply thermal paste tomorrow.
Everywhere there is an arrow in the pic, there is a fan, tried to show you the general amount of fans and airflow direction.
Thanks!
Thanks!
