People online reporting about 30 idle temps with stock cooler? Or is that a minority rather than majority?
Most modern CPUs at stock settings produce very little heat in idle.
So temperature relatively close to ambient is possible depending how speed of fan is controlled.
Now if you're running it overclocked with fixed volts or even at default volts/speed, but with power saving modes (both BIOS/Windows) disabled it's never going to actual idle state.
(those Processor power management settings in Power options of control panel)
And having CPU fan speed control locked to some maximum speed would certainly limit stock coolers ability to deal with lighter heat outputs.
Just removed the whole system, gave it a shake and sure enough it sounds rather empty. Can hear a tiny bit of fluid but not much at all.
I guess that's my issue then! Should it not last longer than a few years?? Got it mid 2014 and don't really even game on my PC so shouldn't have had a hard life
Some evaporation happens always even regardless temperature being below boiling point.
Water molecules can evaporate even from surface of ice. (while some molecules from humidity in air "stick" back to surface)
Only absolute zero temperature would stop that.
Compared to which it doesn't make big difference if coolant is at fair 295K temperature or 20-30K warmer.
And depending on material of tubes some amount of those gas state molecules slip through, because it's not dense/solid enough in size scale of them.
Exactly similar to what happens over time to air filled balloon.
If you think that's crazy, individual hydrogen atoms can diffuse through even structure of metals.
