Yeah was the huge pagefile while physical ram was below 8GB that made me wonder about the ram sticks. If they are not tested individually you can get odd results so might be worth some time.That jump in pagefile usage would indicate a lack of ram - so definitely check the ram usage (both main-board and GPU). With a spike like that and corresponding dip in frame rates I suspect the ram on the GPU may be faulty.
Read the whole thread, and don't see any mention of this unless I missed it.
Have you tried using HDMI from the 1080Ti to just one monitor? Also have you tried removing the Nvidia drivers completely and using the standard VGA adapter, e.g. no driver to see what happens?
I get stutter in every app that uses Hardware Acceleration, whether that's Spotify app, Discord app, Firefox, Chrome etc etc, scrolling looks like I'm getting 20FPS or something, its like a slide show, also looks like the page is tearing whilst scrolling. It also does the same when scrolling on the start menu, settings, etc.
That is your issue, yet you refuse to try using HDMI because you'll notice the difference on the desktop at 60Hz?
Good luck.
I get great frametimes and no stutter when locked at 60 either with DP or HDMI, but 60 is something I don't want to be bound to on a 1080 TI.
I think I read somewhere the Acer Predator screens live yours have 3 settings for refresh rate, the fastest being 165 Hz, can you set it to something higher than 60Hz, but lower than 165 to see where the issues start occuring?I get great frametimes and no stutter when locked at 60 either with DP or HDMI, but 60 is something I don't want to be bound to on a 1080 TI.
