- 14 Aug 2009
I think that as long as you hit 60fps locked (with dlss 3), you'll be fine in almost all scenarios.Why on earth would us pc gamers on high refresh rate displays want that!?
I hope someone does a comparison of dlss 3 vs dlss 2/fsr/xess without showing fps, will be interesting to see which one people would pick out as looking the best i.e. smoothest![]()
Sadly youtube only goes up to 60 fps though so you aren't going to see the benefit with footage over 60 fps (unless it is slowed down as DF did), main benefit will be for games like cp 2077, portal rtx etc. maxed i.e. where fps will be 30-40 without any upscaling tech.
Intel apparently are looking into a similar solution too (makes sense given their focus on machine learning/ai too) and eventually amd will follow....
