Will I die?
31 Oct 2004
London
So wonderful people of OCUK. The case came off my pendrive, shown below:
If I touch it, will I die?
Thanks.
Everyone will die someday.
One of mine has been like that for months. You have nothing to worry about. Besides, they are so cheap it almost seems pointless not to replace it.
Now that's not nice :(.
Serious question though, iirc USB is 5v? Just not sure on the ampage, just rather not pull it out and get a shock :(.
Of course you won't, the shock isn't even string enough for you to pull away. It's like bad puns and needles. Had a dodgy USB port that always shocked me if I plugged something in.
Thanks.
No, but you will be digitized and saved into a world of bits and bytes, where you will be hunted down by antiviral Programs and your only hope of survival is to locate and disable the Master Control Program......
