Thanks, I will try this later onPerhaps just some mould or the chemical resiude from being in storage?
I'd wipe with microfibre cloth and some distilled water.
Yep, all done. I re-ran auddysey earlier, then manually went in and made sure all speakers were set to small, crossover 80hz, subwoofer lfe only, set to 120hz. I think that's itDon't forget you'll need to re-do the denon setup, levels, distance, EQ, speaker crossovers, manual check levels.
I turned dynamic eq and volume off. I have never used the app, or rew to tweak any further settings. I wouldn't know where to start to be honest.There are also EQ modes, I think reference and flat or something one rolls the treble off the other leaves it alone.
I don't think that model has phone app room EQ support where you can tweak room EQ settings? That allows you to set the correction cut off point, typically you don't want full range room correction, so it allows you option to correct <300hz only for speakers and sub.
From my own REW testing, my speakers are pretty flat above 300hz.
Here is a picture: That is tripole right?Are you sure they're tripole? Not dipole or bipole?
Whether what's best for those speakers if you get atmos supposedly diffused speakers aren't ideal
So an update on this, the marks would not come off. I reached out via the retailer to wharfedale who confirmed the finish is defective. They offered me 4 new woofers to replace my self. Or a collect and deliver replacement. I went for the brand new replacement as I don't want to be messing around with brand new speakers and just want a factory mint condition pair. So these will now be going back Monday and a new set delivered Wednesday. Not looking forward to carrying these 30kg speakers up 3 flights of stairs LOLDoes anyone know why the rubber around the cones is discoloured like this on both Evo 4.4s? The Evo 4C does not have this, nor do any of my Diamond 9.1s Is it normal?
Is it safe to wipe off / touch? Don't want to damage the speaker or anything
