Hi all.
New to the community and finally looking to really plunge into PC gaming.
I have a new workstation in my possession, a Lenovo P410 to be specific. From what i know, i believe that i can use the machine as it is to just about get by with gaming, but i am keen to really push the boat out here and upgrade (where needed) to get the best gaming experience.
Let me give you the details of the machine
Processor Xeon E5-1620 v4 4C/3.5GHz/10MB/140W/DDR4-2400
Graphics NVIDIA Quadro M2000 4GB
Memory 2x8GB RDIMM DDR4-2400 ECC
Storage Controller Onboard SATA
Disks 1x256GB SSD 2.5" SATA6Gbps Opal+1x1TB HDD 7.2K 3.5" SATA6Gbps
M.2 Drives None
Optical HH DVD±RW
Power Supply 450W 92%
Im looking to achieve 4K gaming at as high a frame rate as possible. I know that i will need to change the graphics card, and upgrade the power supply to achieve the performance. Will the upgrades be a simple swap out? DO i need to factor in the motherboard and potentially change it?
If anyone has an understanding of what will need to be done to achieve a decent gaming rig, i would be eternally grateful. As i mentioned, i'm new to PC gaming and eager to understand more
Thanks in advance
M.2 Drives None
Optical HH DVD±RW
Thanks in advance
