I was about to put my AW up for sale with a view to buy the G8 but then realised the G8 has fewer features that are actually useful and more features that are useless for me :/
No USB hub, only 2 USB-C ports, that's useless! I often use all 4 USB-A 3.1 ports on my AW and use the bottom ports for quick connections for thumbdrives or to charge something when the other cables on the desk are in use since the right side bottom port outputs a higher current for charging purposes. At least my work laptop has a USB-C port so charging, data and everything else is done via that, but then I'd need a USB hub to plug in the Bolt dongle for my mouse/KB and USB mic since the G8 has no USB-A ports....
Sod it I'll just keep the AW and file another replacement when this burns in before the warranty is fully up lol. The low resonance hum has slightly lessened as it turns out, maybe the fan bearings needed to bed in or something I don't know, still audible though as they all are if you have a PC that;s quieter than a laptop like mine is. The sheer comedy that my monitor is louder than my high end gaming PC is quite something.
