- 2 Apr 2018
Does anyone own or know of a cooling solution for the VRMs on this board over the stock cooler.
Unfortunately EK dont plan to make Monoblocks for this board but im curious of compatibility or alternate ideas. I plan a modest CPU overclock but nothing too crazy and im concerned about VRM temps.
I own a CaseLabs STH10 with more than adequate airflow for the MB chamber.
UPDATE
Trying to find a compatible monoblock. From what I see their could be options from other Monoblocks, designs are very similar but obversely without measurements it's impossible to be sure.
UPDATE #2
Decided against the X299 and went with Z370 & 8700K instead.
Query Closed.
UPDATE
UPDATE #2
Query Closed.
