- 26 Aug 2004
yes m8 it was the new version with 120hz panel
Did you notice any speaker distortion/rattling on your Z35P? How about the vertical split issue?
Were your AOC's black editions or the earlier model?
It really puts me off buying ultrawide g-sync. I've seen a few of the Samsung freesync ultrawides through various friends, and none of them suffer with these issues. Of course, they may just have been lucky as I'm sure they have their share of issues as well.
I really don't get the issue, its just the same as I get from mine and It doesn't upset me what so ever, when your actually playing games in dark places i don't see it anyway.
X34A here
I have no problem with bleed on x34p but the IPS glow and uniformity of the panelAll down to your tolerance. If it is not to your standard or spec, and is bothering you then i'd return it and try again. Took me several attempts on IPS monitors to get a decent one. Can run my 27" IPS with 100 brightness with next to no bleed.
glow is normal for an IPS panel which usually is blue. Bleed is not and that is the yellowing in the corners.
If it is bothering you or you find it not acceptable then return it and try something else.
exactly, it disappears when i look from the angleGlow can be yellow... the way to tell is if it disappears when you move your head. If it does then it's glow, if not then it's bleed.
If you want good blacks you would be better with a VA monitor or a TV. The one in the picture is on the better side for IPS monitors, really not bad at all.
The problem with VA is ghosting/smearing, so you're potentially swapping one annoying issue for another. This does vary between models though, and is atleast something you can investigate and look at reviews for to determine how bad it might be on any given model, plus taking in to consideration games that you play. This isn't something you can do with bleed/IPS glow, which is one big lottery, and when severe enough renders the monitor practically useless for anything as it's always there. Not that VA can't suffer from bleed also though.
I know about all of the pros and cons of the different panel types, but just saying if he wants better blacks then that would be the only option.
I would have to say blacks / contrast are pretty terrible on IPS, when compared to other options, other than that they make good PC monitors, also a trick with IPS is always use in a lit room and use a bias light, that will make it look literally about 10x better.
Depends on the monitor. I'm on a 4K IPS at the moment and have no issues. And I've used plenty of VA panels. Yes they're better, but not correct to say all IPS are terrible in comparison.
No I said IPS blacks are bad in comparison to something like a TV or some VA monitors. I have an IPS monitor and overall they are mostly good, but lets face it the blacks / contrast ratio are not its strong point. Not so bad in a bright room but pretty poor in a dark room.
All IPS have a contrast of 800:1 to 1300:1, so all IPS monitors have relatively low contrast / not very good blacks, but yes bleed and glow can be different.
