Gosh I looked at them again and well I have no idea how but they are very dark. The pictures that is more accurate looks like one belowIf those pics are more accurate regards what you actually see with your eyes, you have a very good panel there.
so nohing then ... no opinions
well m8 i would rma it if i knew the glow i have is ubnormal or it is typical for this panel
m8 that wasn't my question, is there a chance to get a better one or all x34p suffer that glow on the bottom left?Just return it if it bothers you... if you're within 14-day period.
thx for an answerAll X34P exhibit some glow, you can keep trying until you find one that's acceptable to you. There is no perfect panel though.
Personally if I don't notice it in normal use I'd keep it.
t
thx for an answer
t
thx for an answer
So there is a chance for zero glow on the left then
I have the same glow in the left corner as well am I happy with it no can I live with it yes. Chances of getting 100% satisfaction through RMA with IPS panels are really stacked against you.m8 that wasn't my question, is there a chance to get a better one or all x34p suffer that glow on the bottom left?
sadly monitor started to flicker at 120hz, lowering OC down to 115 fixed it for now .... 3 weeks thats how long it worked .
replacement arrived and 2 issues, much bigger backlight bleed especially on bottom right corner and i don't now how is it possible but the colors are much worst and i can't calibrate them properly
my x34p started to flicker after 3 weeks on 120hz, i must be the most unlucky person ever
lowering OC to 115hz fixed the issue but I was sure it will start to flicker again so I returned it and get a new one, sadly the new one is with blb in bottom right corner
