orangeman2003 said:did u get the mic working
ive got sound just when i record myself on sound recorder or use msn it comes out really really messed up and really fast on sound recorder
any light shed on this would be ace thanks
House said:The only thing I would say is when your using speaks for game sounds you need to make sure you get your levels set just right or people get your game sounds constantly transmitted which is really really annoying...
House said:Ok I just selected it as the Sound device in Teamspeak2, 360headset it showed up as... The sensitivty is quite diffrent to my other mic so i had to adjust the Voice activation and leves abit but it works fine.
To use it with MSM you need to select your voice record and playback to the headset in audio devices.
Tom|Nbk said:Im off to the local to pick one of these up this afternoon , hoping it works with TDU and GTR2
Sumanji said:Small word of warning (will add this to the first post as well):
I initially installed the receiver plugged in to the USB hub on my monitor, but now I want to hide it away behind my desk somewhere. However if I move the receiver from one port to another, the pads can no longer sync! I tried lots of things like uninstalling software, trying different ports etc. but nothing works. The pads only sync when plugged in to the EXACT same USB port which I initially installed the device on muchos annoying
Suman
lowrider007 said:works with GTR2 like a dream, don't foget to set the deadzone though otherwise you may find like I did driving straight quite hard due to the pad being overly sensative, the triggers are soooooo handy with this game also
gavinpoo said:I got one of these receivers today. Cut just below the line on the packaging and went straight through the cable. Gutted!
From the looks of it, even if I'd cut straight across the 'cut here' line I would still have gone through it so might try and blag one from Microsoft. I'm sure they'll tell me where to go though!!
rhymin said:these new official drivers mess up ventrilo tho
makes me sound like a robot, have to unplug controller, reboot, then ventrilo is back to normal
soon as i plug pad back in, i go all roboty again, must be something to do with the headset port (which i wouldnt use), gonna try those xbcd ones later
