Dude.
Need a little help with my 3930K + H100i + Sabertooth X79 getting stable at 4.6Ghz properly.
First of all, i can bench at 4.6GHz and 2390MHz RAM, easy. But Prime fails very quickly. I think my CPU is just naff and i lost the lottery. 4.5Ghz is rock solid @ 1.38v set and 1.35v recorded underload and with 2333MHz RAM at good timings.
Here's what i bench at:
36 x 127.75
CPU Vcore: 1.4v
VCCSA: 1.15v
VTT: 1.15v
PLL: 1.8v
DRAM: 1.6v
LLC Medium
130% CPU Current
120% VCCSA Current
130% DRAM Current
All Phase Control @ Optimized
I've tried:
1.41v cpu - No difference, and starts to get toasty
1.2v  VSSCA - No difference
1.2v VTT - No Difference
Lowering RAM overclock - No difference
PLL @ 1.85v - No difference
Any ideas where i should focus my efforts? Or should i just give up on the CPU? I was wondering about the Turbo Power settings.... These aren't mine but they show the max settings, i have them set to Auto. Is there anything like this on the RIVE? If so, what do you set them to?
In fact, I will get screenshots of my 24/7 4.5GHz settings for you and create a separate thread.
