- 5 Apr 2008
Hey.
Got an xbox 360 mod in store for you....
Special thanks to shinester184 for swapping pump tops with me as mine didnt fit!
Plan is for a fully internal watercooling system using a 2 x 40mm radiator and the xspc cpu/gpu waterblock.
I have seen many watercooled 360s but hardly any are fully internally watercooled... but instead have ugly tubing coming out of them which is a mess.
Here is my progress so far...
Still needs another coat of paint
DVD drive window fitted
