Also your NB frequency is underclocked, you might want to knock the multi up one.
Plec - I see you have a similar rig to mine.
Have you done any testing to see the difference between 1600mhz with CAS 9 and 1333Mhz with tighter latencies?
It's just one problem I've got now and while you two magicians are here I may aswell point you in the direction of it
http://forums.overclockers.co.uk/showthread.php?t=18327186
It's the boot up issue that sometimes it won't boot![]()
Sorry i haven't, mainly because reviews have shown that 1600MHz memory is the sweet spot for sandybridge setups. They indicate, thus far, that there's very little gain in higher frequencies or lower frequencies with slightly tighter timings.
Plus, i'm on my second batch of memory (2x 4Gb - my sig is out of date) as my first set were corrupt so i've been monitoring it at standard spec but at 1.5V.
I already had 2x2GB or XMS3 so I bought another 2x2GB - I would much prefer 2x4GB sticks.
I didn't know if I had read about SB not having any gains over 1600Mhz memory, I must have done if you confirm that is correct.
I do have a voltmeter yes.
I've had rigs that'd pass 8hrs+ of Prime but fall over in 5mins on LinX. Whereas I find that if my rig will pass 20 loops of LinX it'll pass anything.
