Why - all that does is disable the fancy stuff, it has nothing to do with responsiveness of the os, the speed the windows open/shut with the fancy stuff on isn't an issue, that's not really any different, its more the physical menu's being slow which in turn slows me down - for example in xp you can adjust (tweak ui) the menu speed, none of the adjustments in the effects tab can change that.
Well i posted that because of this line you said earlier "However the os feels slower due to all the fancy animations etc they have on each window, especially if you've tweaked xp to your liking etc."
. Its the time it takes to do the little things which take time, not the opening and closing of windows, that isn't done very often.
