- 6 Jan 2013
- Rollergirl
Get some bananas plugs!
I have them on the speaker side but the Yamaha unit doesn't take them. Maybe I need to use some cable crimps...
I'd like to hedge my bets a bit and buy something that I could use with a 5.1 in future if I do decide to upgrade the amp.
That's no good for your right now as it doesn't include speaker-level connections. It only has Line/LFE on RCA. You don't have a subwoofer output on an RCA on the Yamaha amp, so you can't marry up the Dali sub unless you change the amp. TLEdit 2: Would this unit compliment the Spektors? Dali C8D Subwoofer Black Ash https://www.amazon.co.uk/dp/B07CHW742N/ref=cm_sw_r_apan_glt_fabc_EBEE9K020NA7KQY1BP1K
Also, the speaker cable I'm currently using is linked below. It's too think to double up one of the Spektors and the subwoofer so I need an alternative quality cable that is thinner. Again, any suggestions welcome.
Current (too think) cable: KabelDirekt - Pure Copper Stereo... https://www.amazon.co.uk/dp/B01C79XV5W?ref=ppx_pop_mob_ap_share
?one of the Spektors and the subwoofer
Are you even bothering to pay attention to what you're doing or are you just wasting everyone's time?
What does that mean exactly, are you saying I would double up the connection to the amp with one of the Dali speakers?
Yup. No problem it doesn't draw power from your amp.
I just bought a REL T Zero MkIII from my local Richer Sounds they price matched it with another online retailer selling it for £349 and knocked a tenner off so I got it for £339. I also have a pair of Dali Spektor 2's and they work really well together. It's amazing how much more enjoyable listening to music is with a sub, so I'd recommend it.
REL reccomended using the supplied high level cable and it's easy to cable in, this was ideal as my CA AXA35 has no sub connection.
But neither I or the OP have your standmounts. I like the OP wanted something to boost the bass of Dali Spektor 2's, I contacted REL and asked for their recommendation based on my equipment and room size and they said the T Zero would be a good choice, they did say the T5 would offer more performance but it is too big for my room. The OP has the option to buy the T Zero from Richer Sounds and return if he doesn't get on with it but I'm pretty sure he will.It's barely a sub 6.5" and 37hz at 6db? My standmounts pretty much same f3
No thanks, I'm more than happy with the T Zero, it has its own 100 watt amp and all the bass I need. REL specialise in subs, it's all they make, they know what they're doing.Then get a 10" sub 6.5" is not a sub it's a midwoofer
Yeah you're right, my personal experience of a product, my communication with the manufacturer about the right product for my needs, my time with Richer Sounds getting their recommendations and insight, my demoing different subs at the store, the fact that I was in the same position as the OP and found a solution that I can personally recommend, this is all irrelevant to the OP and he should only listen to your self opinionated posts based on nothing but personal bias. I'll go back to the hole I came from and no longer challenge your obvious superior insight, +1 to my ignore list.£400 for 6.5" sealed box with 100w amp and light in weight
Lol ..ripped off mate
Get bk Gemini or xls200 instead. Or get two Gemini for even more even response.
Wharfedale SW150 worth a shout too, one of the most popular budget subs.
Good luck
Ok, you've been really helpful and I do appreciate it. However, you'll need to understand that if you want to assist people who are clearly at novice level then it'll take some patience.
The reason I thought I had to connect the sub with one of the Spektors was due to this exchange earlier in the thread.
In answer to some of the previous questions:
The high level connection uses both the left and the right amp speaker feeds. There's one ground connection shared for then two channels, then the left and right positive signal feeds are summed to mono to drive the sub. Three connections in total.
Look at BK Gemini, Double Gem, XLS 200, XLS400, SVS SB1000, Monoprice 10"
