Agreed. While it certainly is a monsta, fitting the thing is most cases will be difficult aswell due to it's thickness. Having said that you would only need one loop with this so it might negate the difference in space needed.
Interesting that it has side vents...
I don't know whether it would work, but could this be mounted with fans on both sides pushing inward, and then exhaust out through the side, in order to create a higher pressure over the fins?
Or perhaps with a blanking cover over the back, to allow airflow in an L shape?
you ordered from ocuk?Got mine
Damn, it's expensive, but I assume it destroys the 480mm in performance? If not... there is no point in it at such a price£175 on a rad, crikey!
