I read something online also about someone saying that the strips are better, as although they're not as accurate, they're accurate enough to know there's a problem
Is there no decent, well priced digital solution yet? I previously looked at Seneye but it doesn't do everything and you need to buy the slides each month.
I found a good thing on Amazon that digitally reads the pH but unfortunately it only existed for pH. I'm guessing detecting the rest of the stuff is more tricky to do with simple electronics only
That's the reason I recommend them, accurate enough to know you have a problem and there not that worse than the liquid kits in terms of accuracy. Once you realise all kits are inaccurate it puts the strips ease of use into perspective.
I have a PH pen which is reasonable, can take up to 30 seconds to stabilise before you can take a reading unlike the TDS meter which is instant.
Got everything you see in the image below for £120 inc fish and everything else, plus load of extras, filters, testers, food, the lot! they are moving abroad so wanted rid. I plan to get a 3d background, or just move away from the print background, anyone had success in making one? I also would like to add sand as a substrate, I have read that play sand is a great cheap option, has anyone else done this?
Having used play sand I would try and source something with a larger grain size if possible but it can work. Try not to go too thick, no more than 1 inch otherwise you can run into problems with toxic gas pockets forming as the sand gets compacted down and anaerobic bacteria form. The counter to this problem is to have fish or snails etc that burro through the sand and turn it over regularly.
