- 14 Jan 2014
Looks ace, A4L tank? Sure I seen it on their FB
lots of sps, tangs as long as they don't kill each other lolLook forward to what you’re planning to setup in it.
It’s been a bumpy week or so with ours. Tang got white spot again, plus black spot. The cleaner shrimp cleared black spot and the reef medic treatment seems to have cleared white spot, but I’ll treat for longer this time. The tang seems a bit up and down, fingers crossed it’s ok.
The anemone has hopefully given up trying to take over the Xenia’s spot. The Scoly shrunk for a day or so, I don’t think it liked the white spot treatment landing on it, so I now dissolve in water before adding.
Hoping to get a livestream camera setup on the tank in due course.
Once we reach stability again will look to add some more fish and coral.
Probably going to be ridiculed for being basic after reading the last few pages but here goes.
My son struggles with the world. He's had a rough start, hydrocephalus detected whilst he was in the womb, neurosurgery when he was 2 to install a shunt to drain excess brain fluid & coming up to another surgery as the valve in his shunt has failed (lasted 15months, meant to last 15 years)
We have discovered that his anxiety wanes a little when he watches fish in a tank. We were at a friends and he just sat quietly for 35 mins enthralled.
So we've bought a tank, filter and everything needed such as tap-safe. It'll just be a cold water tank, few goldfish. Nothing grand but I was wondering, before I go get it all set up, is there I need to consider.
Tank is one I got off FB, 110L capacity
Sorry to hear about your son, but glad that he likes fish! You may be pushing it with 3 goldfish in a tank that size, they get big and are very messy fish. What length is your tank though? Looks decent and you defo have some options stocking wise with 110l. I've never purchased a second hand tank, but many people recommend water testing it first to make sure all the seals are intact and there is no leaks etc, so I would start there.
@Resident
A dark background will really make them stand out. I bought some black plastic that they use to black out glass from eBay.
Width: 80cm (31.5")
Height: 40cm (15.75")
Depth: 35cm (13.78")
I filled it and installed everything including the filter and left it for 24hrs, with the filter running. No leaks and crystal clear water.
Mrs took him for a look at some fish this morning. Came home with a goldfish and a Shubunkin.
My main concern is algae build up though I'm told I can get a fish that eats it so will be looking into that.
Wow! That inspired. Fresh or salt?
Salt, its the last tank i am buying(coughWow! That inspired. Fresh or salt?
I've been having to turn the U4 filter off while I feed my ~14 year old semi-blind Leopard Bushfish all summer, to help it spot food sinking. We went away for a few days on Monday morning and stupid me forgot to turn the filter back on after giving bushfish last feed before we left, first time I've done that. Just like my African Butterfly and Knife Fishes in other tanks, bushfish can breathe air. Any other fish would I have these days would have probably just about survived my stupid mistake, but not bushfish's only tankmate, an ~11 year old Rubbernose Plec that are very oxygen sensitive. Gutted.![]()
I have a routine on alexa called feed the fish, which turns off the smart plug that the pump is plugged into for 7 minutes for a similar reason. I never have to remember to turn the pump back on after feeding.I've been having to turn the U4 filter off while I feed my ~14 year old semi-blind Leopard Bushfish all summer, to help it spot food sinking. We went away for a few days on Monday morning and stupid me forgot to turn the filter back on after giving bushfish last feed before we left, first time I've done that. Just like my African Butterfly and Knife Fishes in other tanks, bushfish can breathe air. Any other fish would I have these days would have probably just about survived my stupid mistake, but not bushfish's only tankmate, an ~11 year old Rubbernose Plec that are very oxygen sensitive. Gutted.![]()
Any updates on this one
